spinning 35mm question (pleasseee help)
zipper1022
hey im building the cd player/ spinning 35mm adapter and i was wondering if it mattered how far away from the gg i put the macro...
most people have used 2 inch thick enclosures but radio shack only had a 3 inch one so i got that....
do i want the macro to be close to the gg or far?
i can always cut teh project box so shorten the distance...
ALSO, DOES ANYONE HAVE AN EXTRA FROSTED DUMMY CD????
i sanded a plain one lightly with fine sand paper and it came out okay... anyone have an extra premade one???
hi zipper,
normal distance from gg to camcorder is between 30 - 50mm its not that important. Depends on your camcorder model. If you have a camcorder with lens thread smaller then 43mm you wont need a macro at all.
Fix a 35mm dia slide to the wall. Distance from camcorder to dia slide 30-50mm and try to zoom in just enough to fit the whole viewfinder/LCD with the dia slide. If you can focus on the dia slide without problems take the measured distance and use it in your dof adapter.
best regards
Daniel
http://www.jetsetmodels.info/news.htm
cool thats really helpful...
another thing i noticed as i put it together...
when i was checking the diy it said to assemble the 35mm lense and the gg and then point it at a far away object, IE tree building etc...
i did that and the image that it projected onto my gg is weird...
i see the whole image, but there is a circle of it, (the same size as the back glass of the lense) that is seen in my image...
will that circle go away when i put it in the project box and close it up?
I hope I understand what you are asking, the lens is projecting the image in a circle shape, instead of the rectangle you were expecting? You'll just zoom into it and only record a rectangular portion of that circle.
If you have a canon Hv20 and trying to make a Spinning adapter, do i need the macro on that? I mean, i think it's a 43mm lens
