reaktor
A while ago I decided to build a diy 35mm adapter for Nikon lenses. I decided to create a spinning model. Afterwards, I decided that I would need a rail system so I got to work. I didn't want have to wait on parts to come, so I took a trip to "The Home Depot" and found whatever I thought I could use.
For everyone who has been dying to find 15mm rods, copper 3/5in plumbing pipe is almost perfect, and its like 18 dollars for like 10ft.
The purpose of posting this isn't just to show off 2 of my first diy projects, but to show people that they can build a rail system for extremely cheap from parts at The Home Depot instead of going and spending lots of time and money buying specialized parts from manufacturers etc..
Additional images can be viewed at http://reaktor-films.com/diy/images/
The parts used:
3/8in to 1/2in Conduit Hanger
Store SKU# 856460
1/2in Set Screw Coupling
Store SKU# 839671
Copper pipe for plumbing, the store near me has these approx. 2ft sections precut instead of buying a 10ft rod.
The plates and everything slide when untightened. The screws don't really matter, and same with the nuts. The piece holding the plate for the camera up are two pieces L pieces of steel with holes for variable heights drilled in it. The plates themselves are aluminum I found and cut, it can be replaced with any material. I drilled all the holes in the plates myself with a drill press, but it can be done with a power drill. Oh yeah, I painted it black too... like that stones song.
You can do this too, I'm 17 and don't have any shop class experience or anything. It was absolutely simple.
1. Just take the base plate and the conduit hangers, take out the screws on the top.
2. Take the screw and nut you're using, and put in in from the underside of the plate.
3. Now put the nut on from the top.
4. Tighten it using a wrench to hold the nut, and a screwdriver or drill to turn the screw.
There is a small nut on the lower plate, that connects to my Manfrotto tripod clip. the screw is just long enough, I'm going to get a standard 1/4" 20 turn screw and use it instead of the standard screw for the extra length.
Yeah, the plate is totally sturdy. It's real strong metal. (use with 35mm adapter and DVX100b)
The parts used:
Store SKU# 856460
Store SKU# 839671
Im havin trouble building this...Can you help?
Im having trouble tighteing the screws that hold the conduit hanger into the board. Those are my main issues, getting the screws tight because they are a little awkward to get to.
Got any solutions?
How is the entire rail system attached to your tripod?
Wow. this is really good! Does the camera plate provide enough support?
