sparks like effect when exporting to avi
thewheel
i imported some footage after editing in premiere.after doing some level changes i exported from AE to avi. the end result is as expected if it was not for sparks like effects randomly in every part of the resultant movie when i play in media player. although i have not tested this on a TV yet i am sure that the end result will be the same since i have noted this when doing some text in an intro which at the tie seemed like text not rendrred well. any idea why? i shot in progressive and i have set setting in premiere to note this before importing to AE. am using PAL. any ideas why? 10x.
the reason for those sparks was that when exporting from AE i used video setting -> compression DVCPRO. I have exported to compression NONE and the sparks disapeared. To my surprise however the sparks remained when i exported to compression DV-PAL. 3 minutes of uncompressed avi however used 3G of harddiskspace. can you assist me in uploading an image, i read that you need to insert an img tag in the help and in the FAQ it refers on using the browse button at the button of the page but i could not find any browse button...and i work in IT :)
just put
B] at the start of the url for your image and [B]
at teh end, with no spaces in between.
