RedGiant Active member Jun 14, 2007 #1 Does anyone know which cameras need a spacer tube for use with the M2 and which don't? Is this published somewhere? Or more specifically does anyone use the DVC30 with the M2? If so, do you use a spacer ring?
Ryan Patrick O'Hara Veteran Jun 18, 2007 #2 the following cameras require a spacer tube: Sony Z1 (if using Redrock SD achromat) Sony FX1 Panasonic DVX100 (non-A) Spacer tubes are available from www.cameragear.com. I am not sure when they made this list if they considered the dvc30. I would write them an email.
