When I export the master mix back to final cut there is no audio. On previous projects ive done it the same way and its worked fine but for some reason im not getting any audio after exporting now.
Any ideas?
Aftter I import into FCP I get this error message...
Sat, Feb 23, 2008, 5:36 PM - Errors Found Importing monstersoundfinal3wave.xml
<link>: <linkclipref> and other <link> data mismatched. Data defined in <linkclipref> element will be used.( line 508 )
<link>: <linkclipref> and other <link> data mismatched. Data defined in <linkclipref> element will be used.( line 502 )
<link>: <linkclipref> and other <link> data mismatched. Data defined in <linkclipref> element will be used.( line 1510 )
<link>: <linkclipref> and other <link> data mismatched. Data defined in <linkclipref> element will be used.( line 1504 )
<link>: <linkclipref> and other <link> data mismatched. Data defined in <linkclipref> element will be used.( line 2088 )
<link>: <linkclipref> and other <link> data mismatched. Data defined in <linkclipref> element will be used.( line 2082 )
<link>: <linkclipref> and other <link> data mismatched. Data defined in <linkclipref> element will be used.( line 2385 )
<link>: <linkclipref> and other <link> data mismatched. Data defined in <linkclipref> element will be used.( line 2379 )
Any ideas?
