Noiz2
Sound Ninja
Here's a newbie question: If all the inputs are mono inputs, then why does each fader have a balance (L-R) control on it? What's to balance if there's no stereo input?
A good way to think of a mixer is that stuff pours in from the top (back) flows down the channels and then flows to the right and out.
Your mixer has 16 mono inputs and two mono outputs (plus some sends for FX and such). The two outputs can go to two speakers and if so then you could send stereo content to them.
But it's important to remember that stereo is a very specific thing, not just two speakers getting some sound. The mixer is sending two channels of audio but they are not necessarily stereo. If you take a mono signal, say a mic, and send it to both speakers by setting the pan to center you are sending a MONO signal to two speakers, it is not stereo.
So the basic answer is that this mixer is set up for live shows and it is really built for sending multiple mono signals to two speakers. The pan control (balance) sets how much of that mono sound will appear in each speaker.
You can create a stereo mix by taking those mono signals and panning them to different positions. The individual mics will "appear" to come from different places between the two speakers. Or you can pan them all center and you have a mono mix in two speakers, and everything will "appear" to be playing centered between the two speakers.
A lot of time you will want to spread things out a bit so that the sound appears to come from a position that more closely matches where the mic is on stage. Or just so the sound is "wider".
Some mixers have stereo channels and those would have worked (probably) with the cable you had. However you would still want to go with two mono channels so that you could do the one channel to both speakers thing you describe.
