Hello all,
I am new on this forum and I am also a real "beginner" went it comes to sound. But I want to learn so here are my questions.
I did some tests on my panasonic DVX 100B with the wireless Sennheiser G2 SK100.
The settings where the following (it was for an interview)
The transmitter was set at -10 dB and the receiver at -24 dB. It gave me a clear sharp sound without any feeling that the person I interviewed was talking in a "can".
In my opinion it was the best result I could get
I did other tests at -18 dB and -10, but the results where like if someone was talking "in a can".
At 0 dB it was really really horrible..big distorsion
I did the test in a silent enviroment without any surrounding sounds I must say. Is that the right way to test the mics or I should do test with lot's of noise around?
Are those setting normal? Because a friend soundman told me that both the receiver and de transmitter should be at 0 dB but I got horrible results.
And also I would like to know this....MUST the receiver and the transmitter be at the same dB? ot is it normal that during my tests, they where set at different levels???
Can someone who knows the sennheiser G2 help me ??
I read lot's of posts on this forum, wich is really good by the way, but I did not find this specific answer
thank you so much:laugh:
kat,
P.S I should add that I will be going to Afrika alone to shoot a project for many many weeks. I don't have budget for a sound man (unfortunately!!!) so I must do it alone...
so keep in mind that I am filming and that it must remain simple.
I plan to use a sennheiser ME66 as the external camera microphone so I can do "small" interviews on the spot.
I will follow poeple around and my main caracter will alway's have the lavalier mic on, so I can get clear sound.
I will also use this lavalier omni to record "general sounds" (put it somewhere in a corner) that I can mix later on with the general sounds that will be recorded with the hypercardio ME66..that I plan to leave on the cam on a mini mount
kat,
