sound problem with EX1
golasa
Hi all,
Occasionally (that is to say that I could not detect why:)) I got one of my sound input line disabled.
Audio set-- audio input-- trim ch-1 may be enabled whereas trim ch-2 is disables, and the menu 'jumps' to AGC LINK LINE.
As a consequence, I cannot modify its parameters. I can however, hear and record on both channels.
FYI, I use two external channels, one for HF, the other for direct, both scennheiser.
I must miss something obvious, but cannot get it.
cheers
sort it out.
I actually put the second mic on Line, to reduce the parasite noise (at the same time I increased the receiver and the transmitter)...but as it's on Line the Trim is disabled. I had to put it on mic, dialed my tune and turned it back to Line.
cheers
