dwnsthballer
Hey everyone,
I'm really getting into learning and acquiring better audio for my shorts, and looking into purchasing a pre-amp for my Oktava, and I've heard a lot about the quality of Sound Devices products, so I was wondering what you guys take on the Sound Devices MM-1 pre-amp was?
I did a search and found a little info on it (all good), but I figured I would make a dedicated thread for it to hear from you guys. At first I was thinking of buying a SD Mixpre, but I'm only in need of a pre-amp really (don't need the extra inputs, plus money is low). My main questions are:
1) Overall quality of the MM-1.
2) Good idea or bad idea? Going from mic to pre-amp to camera, or is a mixer absolutely needed in the chain (if I'm only using one mic)?
3) A constant problem I have is overmodulating and clipping (probably from a lack of a sound guy). Does the MM-1 have a way to set a limit output to my DVX (I know with the 302, you can set the output to your camera with a test tone and such. Is that the same for the MM-1)?
I'm doing research on it myself, but it always helps to have real users break it down for me.
Any comments is gladly appreciated! Thanks in advance.
