Sony MDR 7506 chord shorting...is it replaceable?
jambredz
Title says it all :)...i need to replace the chord on my 7506 ...is this easily done? Where can I get a replacement...preferably a straight chord this time.
I replaced my cable with a straight one, too. I was tired of the coiled cable getting tangled. I got about 6 ft of Canare L2B2AT and a Rean 1/8" connector. It was super simple to solder, just 3 wires on each end. The hardest part is getting the ear pad back on! Once the pad is removed, there are a few screws holding the driver to the can. Open it, de-solder the wire, pull it out, put the new one in and solder. Took me about 20 minutes.
The original cable that comes with the MDR 7506 (and most similar headphones) is very tiny and difficult to solder, even for those of us who have been soldering cables for many many decades. Of course, replacing it with some more conventional cable (as edinc90 demonstrates) is pretty easy (except for those OEM ear pads. The replacement pads (same ones that fit BeyerDynamic and similar headphones) made of velour are much easier to install, and they last a lot longer than the OEM pads, and are more comfortable, also. For example: http://www.bhphotovideo.com/c/product/886945-REG/Auray_epd_mdr7506_Deluxe_Velour_Earpads_Pair.html
PS: A "CHORD" is a cluster of musical notes. A "CORD" is a cable.
MDR-7506 Repair Manual
This will show you where all the contacts are to be soldered, and how to dismantle the ear pieces. If you know someone local who is skilled with a soldering iron, take him/her a printout of this, along with the replacement cable.
Thanks guys. yeh I may have found someone locally. I did order the cable though. So i'll take the cable and that print out to them. Thanks for the help!
lol@ Richard...yeh i knew something looked wrong about it :)
I have tried to solder sony cable and it is very difficult, its where the sennheiser HD25's are great as you can easily replace the cable or swap from coiled to straight!
The headphone cables are not normal cables, they use a conductor ribbon wrapped around a thread. So what you have to solder is tiny and fragile, a real PITA.
FWIW, Amazon has the 7506 on sale for under $100 right now. I just picked up a set to give them a try.
They also have the MDR-V6 on sale for $60 today.
At the significant risk of exposing further evidence that I am a renegade and a heretic (and perhaps a tin-ear as well), I have several MDR-7506 and several MDR-V6 hedphones, and I can't tell them apart except for the label on the side and the gold-plating on the MDR-7506 plug.
Yes, the MDR-7506 and MDR-V6 from what I can tell are identical except for the plug, label and price.
Trew Audio (and others I would think) has third-party (non-coiled) replacement cables that are much easier to solder that the OEM.. conductor ribbon wrapped around a thread ... and coated w/ lacquer.
Or you could just get a cable from Radio Shack for a few bucks. Available in several price/quality, and different lengths, and even different colors!
In fact, now that I think about it, I wonder if there is enough space for a female 3.5mm panel-mount jack there where the cable is attached.
Then you could use whatever cable you want and detach it for more convenient storage and transport.
So i got the replacement cable. Gonna see someone about it tomorrow and see if it can be fixed. However I also bought the sennheiser hd280 pro...and wow this thing really cancels out ambient noise. Really liking it so far and at least the parts are easily replaceable by the end user.
