Sony Fs 700 + DJI Ronin
Fader8
Hi there,
I got a good offer to buy a Ronin. As I plan to shoot something like a one take (splitted in some takes) - but the feel
should be flowy, I thought about buying one instead of expensive rental. In the package would be a support system
from atlas
Now I know that there are quite some topics on the Ronin, but i thought it's been a while since the release and some
people might have worked with this combo quite a bit: FS 700 (+ O7Q)
I would happy to hear from some experience users:
- is it worth the investment?
- Did it 'boost' your production value?
- is it too heavy?
- do you use a support system?
- do you use the Ronin extension arms?
Happy to hear suggestions/experience.
Thanks.
I have shot with this set up quite a few times. I'm no pro, i just do YouTube videos, but here's an example.
https://youtu.be/_zsQOzfI6GI?t=14s
I mean, i ran full speed through the sand with it. I've been happy with the results. I think due to the pure weight of the FS700 on the Ronin, you don't get as much bobbing up and down from walking as you might with lighter rigs.
However.... i've been looking for something lighter. For me, as a one man band, it's just too heavy. I'm 6ft, 240lbs. Not a muscle man, but that rig must weight 20lbs. It becomes a bit limiting. The next step would be to get a vest and other support gear but i just need to go smaller. But i've done 2-3 minutes before my arms started shaking too much!
I did not use the Ronin Extension arms. I use the Sony 10-18mm Lens, which is very light. So i can balance the camera on the Ronin with room the SDI cable to the 7Q. I had to buy an elbow adapter for the cable, otherwise it stuck out just a bit too far.
I recently tried the Ronin M with the a7RII, and i could control it much better. I could hold the rig at various angles for more interesting shots.
I think if you have a crew, or an assistant to take the Ronin off your hands and return it to the stand after you get your shot, it could be really nice. It's solid and smooth, imo. But just SO darn heavy.
I use the Ronin/FS700 very often. If you can find some of the newer (last year or so) of ESPN show Sport Science, we do almost all our high speed on the Ronin now.
Get the arm extensions, the knock offs are around $100 and work great. You do not need any of the other extensions (drop down or pan arm) these just make the rig bigger and require holding further away from the body. I know some say you can make fs700 fit without the arms, its not worth limiting your lens options and also I think there are a lot (and I see it on the highest level of production) of Ronin users who do not balance rig and get substandard stabilization and overwork motors. Learn how to balance, watch the videos, way too many gimbal users don't understand balance and why it is essential to these devices working right.
I've used the easy rig with flowcine designed to hold the Ronin, I do not like them very much, way too limiting. Instead make sure everyone you are working with understands once you pick it up you have limited time until it becomes too heavy. I always leave the ronin on the stand until i am positive it is go time. Then I pick it up and fly. Using the Ronin 3-4 times a week will get you in the best shape of your life. I honestly like the physical push and also the freedom to move the Ronin wherever I want.
If you do need an easy-rig there are exact knock-offs on eBay for around $800.
BTW I've bought 2 used Ronins for less than 1400 each. Hunt around they can be found cheap.
You need a follow focus. If you want to do interesting shots you need to be able to pull focus. Redrock offers the best combo of finger control and also wireless hand unit. Wireless follow focus will cost you more than the Ronin but it is a required part for dynamic shots.
You also kind of need a wireless video transmitter like a teradek bolt. Otherwise the focus puller is looking over your shoulder.
It's funny how many people buy just a Ronin and think they are all set. If you want to use your Ronin in any professional environment, you NEED focus and you NEED wireless video.
I also own Defy G12, it is lighter than Ronin and holds the fs700 just fine. DJI is just nicer all in one package with the remote control.
Only photos I could find on my phone were in "travel mode" I find using bongo ties to hold the Ronin to the stand works great for car travel. I can pull it out and be ready to shoot in seconds.
paulrossjones - nearly every good Ronin, Movi tech I know uses this technique in some form or another by attaching accessories with dual lock onto the back of the camera to add back weight. If you look at the Ronin, they actually designed a rear mount for the rods to be used backwards with weights on them. Yes it's a game of sliding the camera back and forth to find the center point, fs700 is a very light backend so adding any weight you can is going to make balancing it onto gimbal easier. The other solution like ChadN said is to use a very lightweight lens.
This is why the shape more than even the weight of the new fs5 is appealing for gimbal use.
I would still rather have arm extensions than add counter weights.
