Bassman2003
Yep, power pack works good. I have a 10,000mAh pack and when it's connected without the camera battery installed, you can turn on the camera, work the menus, but cannot record. I'll need to re-do the 4K 30P 100Mbps battery test, as that last try was not a fresh battery. In 4K 30P 60Mbps, the camera ran longer before over-heating. Shut down at 65 minutes and 121 deg. F.
At 1920x1080 60P, and a fresh battery, it ran for 98 minutes, at which time the battery died. The temp hit 108 deg. Maybe no problem then, as Ron expected. The video files were intact in all cases of camera shut-down, recording stoppages.
Thanks for the info but I am confused. How does the battery pack work good if you can not record with it?
