Eatsnax
I've tried everything under the sun. And I cant get this freaking project or any project for that matter to print to video. This is soooooooo hard. I read the manual, I read every post on here, I read every post in every place I could find, I did searches, I did trial and error, I think I just about tried everything under the sun, really. I've even took the project rendered it with current settings and I still cant print that to video! WOW!! I feel defeated, and frustrated.
This is the deal, I have footage that was shot on the HVX at 720 24PN. I edited in FCP 6 in those settings. After I was done I opened the sequence in a new NTSC sequence, so I can print to Mini DV. I get many problems. First when I get the footage to show up in my DVX lcd screen it only shows up as a single frame. I did what I'm supposed to do and that is to click ALL FRAMES in the VIEW section. I still only see a still frame when I play the timeline! Next when I try to PRINT TO VIDEO I get audio only and no video!!!! :kali: ARRRRRRGHHH!!!!
I've tried many many many suggestions here pertaining to this problem. My settings are set to FIREWIRE BASIC, I even tried FIREWIRE NTSC and the same problem arises. I tried turning on the deck first and then starting FCP still nothing. I even checked to see if my AUDIO VIDEO settings are correct, they are as follows...
SEQUENCE PRESET: DV NTSC 48
CAPTURE PRESET: DV NTSC 48
DEVICE CONTROL PRESET: FIREWIRE NTSC BASIC
VIDEO PLAYBACK: APPLE FIREWIRE NTSC (720 x 480)
AUDIO PLAYBACK: FIREWIRE DV
My sequence settings are as follows
FRAME SIZE: 720 X 480 NTSC (3:2)
PIXEL ASPECT: NTSC - CCIR 601/DV 720 X 480
EDITING TIMEBASE: 24
COMPRESSOR: APPLE PRORES 422(HQ)
I believe they are correct, I tried trashing preference's I don't know if i trashed them right or not. Either way I'm stuck and I have been stuck for awhile. I even reinstalled FINAL CUT STUDIO 2 and UPDATED also!!
Is there something I missed that I should know about? This is very hard, any help from you guys that have experienced this problem, or anyone who knows what I'm doing wrong please chime in, I feel so embarrassed for myself that I cant figure this out. :undecided
Thanks in advance.
Thanks in advance.
