filmguy123
Shooting 30p on HVX, but in 480 mode. 480 is SD, and that always plays at 60i.... so really, 30p is recording 60 fields a second, except each field is identical... is that correct? So I actually still have 60 fields every second, except I do not suffer from interlacing artificats?
- Does this make the deinterlace filter useless here?
- Should/could I use the DVCPRO HD Frame Rate converter here to remove duplicate frames (fields)? Would this make the footage the same then as working with say, 720p30pn (except for resolution)?
Next question. An external calibrated monitor has traditionaly always been important when working with DV footage. When entering the all digital realm of HD and progressive footage (unless shooting 1080i) - but lets stick with 720p30p for 60p for now - when dealing with all progressive footage, is an external monitor as important as it used to be? Besides color space/title safe, is there anything else?
If so - for HD, I am assuming you need an HD calibrated flat panel screen?
I am looking for a good external calibrated monitor if still needed. I wanted one that would work with SD and HD - can this be done, or is it best to get two seperate monitors?
What product/brand would you recommend?
