plainman007
Hi,
Just got my new EOS-500d with stock lens kit IS 18-55mm and wanted to know some basic things about how to maintain and store the camera.
1. UV FILTER : Is it good or ok to put a UV filter onto the kit lens ? Will it have an effect on my pictures in any way or it it completely neutral and just cuts UV only ? Im considering this only to keep the main lens protected.
2. LENS CLEANING : How do you guys maintain your lenses. Do you just use a puff tool to clear away dust ? I took my camera out for a few pics and noticed a blob or two of dust specs settled on the front lens. Is it ok to huff on the lens with warm breath and wipe with a clean cotton cloth. Or is it not adviseable to ever wipe a lens, in which case how do you clean it ?
3. CAMERA STORAGE WITH LENS : Is it ok to store the camera with the lens fixed on permanantly or do you remove it for storage between usage days.
4. LENS STABILIZER SWITCH & POWER USAGE : There is a stabilizer on/off switch on the IS lens. Will leaving this stabilizer switch to ON draw power from the battery even when the camera is off ?
5. CAMERA STORAGE WITH BATTERY : Do you guys leave the battery in the camera during storage. If so how long is safe to leave a battery in the Cam. The manual says its adviseable to store the cam without the battery for long duration storage. But what about short duration storage. Like say a week or so. Whats the usual period you guys safely leave the battery in the cam ?
