dylansmith
Some questions below:
1. Coming from a stills background and having used Lightroom for years, I am finding it a bit hard to work on video using Premiere pro CC.
a. Instead of using the RGB corrector or Levels tool, where can I find a multitude of sliders (e.g. exposure, contrast, vibrance) for easier control?
b. I have heard about "masking" as being somewhat equivalent to the target adjustment tool in Lightroom. What is the easiest way to do targeted adjustments (e.g. brighten face in shadow, sharpen eyes) in video using PP CC?
c. How much dynamic range do I have in video mode on my 6D (understand there's RAW video using ML, but it's underdeveloped) compared to stills mode?
c2. Does ALL-I mode really offer more dynamic range than IPB? Or is it only about the NLE editing speed? If it is the latter, I feel absolutely no difference editing either of such videos.
d. What are some of the most popular color grading presets (yes, understand there are purists who prefer to adjust as per the situation) that you guys use for your videos? My videos are 99% about my kids - 1-2mins in duration and usually upbeat/cheery in nature. would love some recommendations please.
e. is h.265 profile fully supported in PP CC yet? Would love to export all my completed clips in h.265 for the best compression possible.
2. On the A7Rii, there is the Super35 crop mode vs FF 4k mode. If I use the former, does it mean my FL gets multiplied and DOF is increased?
3. Why is it that some cameras have a higher native video ISO compared to stills (800 vs 100) ?
4. When doing a cross-fade transition between 2 clips (10s clip each), PP CC says I don't have enough media duration to crossfade, and attempted to freeze my 2nd clip for a few seconds when I inserted the transition effect. How is 10s not long enough when the transition effect is only <1.5s? What can I do to avoid this situation?
5. The Warp stabilizer seems to produce erratic results on some of the short clips I have. Even on a clip that was lens-stabilized and just need a little post-processing help, it literally warps my clip (e.g. stretches faces of people and makes it look like a dreamy scene). Which plug-in do you guys recommend for that little extra help? Lock&Load / Mercialli or some other alternative?
6. What is the industry-standard method to grade clips from 2 different cameras? Is it done through 'eyeballing' or is there a button that can do a best guess to 'sync' the color in post? I currently own a 6D and Oly E-PL5 and the clips are vastly different (the latter's quality is very crappy).
Thanks!
Thanks!
