Moe
I'm using premiere pro 1.5 for editing my video, its very user friendly and I haven't had any problems so far...
I just want to make sure that I'm doing things the right way, some of you guys are experts at this, I would really appreciate it if you can point out if I'm doing anything wrong, or if there is a better way of doing things.
I'm using the 24Pa shooting mode. When I set up for the project I use the following settings:
Editing mode: DV playback
Timebase: 23.976
Pixel Aspect Ratio: D1/DV NTSC (0.9)
Fields: No Fields (Progressive Scan)
Display format 24 fps
Audio: Sample rate 32000 hz
What is the difference in using "DV Playback" or "video for windows"?
also, should I check the "optimize Stills" box?
thanks in advance guys
Timebase: 23.976
