I have a H4n recorder and NTG-2 shotgun microphone for film. The problem is low audio level. I have researched about this problem and I knew some points.
Due to the H4n has a weak mic Pre-amp, this recorder is used for some musician to record their music. NTG-2 is a good microphone for a performer in price wise but not the best choice for filmmaker to record the actor's lines. NTG-2 might not have enough sensitivity for weak Pre-amp recorders. NTG-3 has -30db sensitivity. It is a lot better but the price gap is huge.
I figure out some solution and I need advice.
1. new fancy recorder (Tascam HD-P2) + Rode NTG-2
I don't know how sensitivity Pre-amp inside HD-P2's. Even I have a new recorder, I may have same low audio level problem.
I guess fancy recorder may has better and powerful preamp.
2. H4n + new fancy microphone (Rode NTG-3)
I will have better audio level but I am not sure about the gain.
3. H4n + new fancy mixer (Sound Devices MixPre, MM-1 or MP-1) + Rode NTG-2
I am pretty sure about this configuration but I want a simple setup.
Which one will it be the best choice for me?
Please give me some advice of the lists from above or give me some new ideas in ($700-800 price range)
Thank you.
Thank you.
