gco
I have been using (or trying to use) the Merlin for a while now and I am just not happy with the performance I am getting. Yes, I can balance it and get relatively good results with effort and concentration. However, my primary use is in outdoor situations and if there is the slightest breeze, twigs, leaves, forget it. Basically it just does not balance to the level of stability that I want. I am wondering if I have discovered the limit of its design performance. It seems to me that from a mechanical point of view, it would be far more mechanically efficient to have a counterbalance weight (bottom weight) linked to the cameras center of gravity directly through a rod or post rather than indirectly through an arc. With that in mind, it seems to me that the pilot sled might perform significantly better than the Merlin. So my question to you guys with experience is; is my thinking straight on this?, i.e. is better performance to be had with the Pilot sled over the Merlin or am I still clueless about balancing the Merlin?
Any comments/suggestions/opinions appreciated.
rogar-Smoke(DBG):
