GabePL
I've just started using the HVX P2 workflow and am wondering if my experience is normal, or if there's a kink in my system...
Everything works fine, it just seems that when I import the P2 data into FCP it is very very slow. 20-30 minutes per 4 gig card.
I'm using a Powermac G5 dual 2ghz machine running FCP 5.04. I transfer each 4 gig P2 card from my P2 store onto a 7200rpm maxtor firewire 400 external drive. I then use the "Import P2" option in FCP. This is where it seems to snag. It starts the import, and seems to buzz along fine, giving me a 4 minute estimate at first. Then, when it reaches the end of one of the clips (based on observation of files as they are created in the capture folder) the system seems to hang, I get the spinny ball of death, i hear a whining sound coming from inside my computer case, and the time estimate starts to climb. After a few minutes, it moves on to the next clip, goes along fine, then hangs again, repeating this process until all of the content has been imported. The whole thing takes between 20-30 minutes for a single 4 gig card.
It doesn't seem to make a dif'c whether I use an internal HDD for the FCP scratch disk, a dif't firewire drive, or the same firewire drive as where the mxf files are originating.
Is this amount of time normal in your experiences? Can you think of anything that might be causing these hang ups?
If I just walk away and let it do it's thing, it all seems to work out in the end, but it just feels like there's something fishy going on...
Any feedback or suggestions would be much appreciated.
Best,
Gabriel
Best,
Gabriel
