i've managed to source nichia LED COBs, NSCWJ216A, pretty cheap, 13$ each from a high CRI bin. Will they work well for lighting with dslrs?
Thinking of driving them at 36V 1.5A, finding it hard to get a decent heatsink.
I've calculated at 3.5 sq inch of heat transfer area per watt of LED, so for 200W, 700 sq. inches of fin surface area. actively cooled by a silent, slow fan.
Usually the heatsinks i have seen appear extruded, would i have to get extruded heatsinks or would i be able to manage with a 6mm copper baseplate and 2mm thick aluminum fins soldered to it?
This is going to take months. There will be many, many designs and redesigns, hopefully.
Adding a Cooler Master MegaFlow 200mm, heatsink will have to be square for now, but 100 cfm so maybe reduce the surface area of heat sink.
Resources:
Heat sink design, not too complicated https://www.aavid.com/sites/default/files/technical/papers/how-to-select-heatsink.pdf
Resources:
