Slideshow
FilmMagic
Hey guys,
I'm trying to make a slideshow and I love to put the slight zoom in/out for each photo, however, I'm having a little difficulty. When I zoom in, the picture does get bigger but it just gets cropped at the at the original image size. So basically, after that horrible explanation, the picture doesn't take up any more space on the screen.
Is there any way around this without having to put it in photoshop and add blank space all the way around the image?
Sounds like you''re using Track Motion rather than Pan/Crop? Or, maybe I'm misunderstanding. In Pan/Crop, are you rightclicking and selecting "Match Aspect Ratio?"
Spot,
All I saw was Maintain Aspect Ratio; didn't see Match Aspect Ratio. I am in Pan/Cropand I actually just found a way to somewhat do what do what I want. If the aspect ratio isn't locked, when I scale the height/width (one or the other), the other one doesn't stay cropped. (BTW, this is the biggest pain in the butt to explain.) Basically, I think that in Pan/Crop, it's making the picture size the aspect ratio so when I zoom in, the sides of the pic start disappearing even though there is still blank space around it.
You know there is a script (free) on the VASST site that will auto match all aspect ratios, right?
in the event you don't use a script, you can also right click a properly cropped file, choose Copy, and then select all other images to be cropped/corrected, and right click those, selecting "Paste Attributes." This will do the same thing.
