I'll join this thread for eavesdropping.... Would be nice if anyone have had direct contact with both Konova and Kessler and could offer thoughts on how much they differ in quality.
The Pocket Dolly is probably more portable, and fits in smaller spaces, but then you are limited to it's 4' length, and more limited camera weight it supports.
The Dana Dolly takes longer to setup, but is more versatile, and you can use any length speed rail, so you could do say a 10 foot move if you wanted. It also supports very large heavy camera setups.
I went from those small sliders, some Kessler sliders, Cinevate 30 then Cinevate 200, throw in some power sliders such as Cineped and MYT Works.... and i ended up settling on Dana dolly.
Why, because every shot is precious and there is nothing worse than having it ruined by wobbly slider and slider with some sticky parts.
Cineped and MYT Works belong to their own class and the difference between Dana and those is that Dana is much cheaper and a bit more versatile.
I have the 4-foot Konova K2 slider. $300.
Perfect - for a slider in this price range.
Opened the box, loosened the trolley and ran it back and forth end to end about 5 times, put my Manfrotto head on it and did a test shot - 95% smooth as glass.
Then I actually opened their bearing adjustment kit and instructions they send with it and now it's perfect.
I did a LOT of research and it always came back to the Korean Made Konovos having the best quality-to-price ratio. I'm totally pleased with it.
My rig is a DSLR in a cage with a 7" monitor on the cage. The extra weight improves results - but that should be kinda obvious.
