SLide show
nantnee
Whats a good frame rate for slide shows? 30 doesnt seem to do job. Or does frame rate even affect slide shows?
So lets say there is a clip in my project connect to a larger clip. In order to change from 30 to 60, i interpret footage to 60. This changes everything. How can i adjust the single clip, without affecting the larger one?
First of why does thirty not work?
The Frame rate of the overall time line really depends on where you are playing back. Also, what are you using in the slide show, still pictures? If you are your best bet is to have any moving footage in your show to set the rate to that.
Also, you could try making a sub clip and interpreting that to be different if you want to change just one clip. Also if that does not work, re import the footage so you have two copies of it in the project and interpret one of the two.
Hope that helps.
