RTFM- Page 8. Confirm recording levels/parameters NOT locked.. and vol, are bot locked together as a stereo pair.
I did this and all is unlocked...Page 8. Confirm recording levels/parameters NOT locked
http://www.dvxuser.com/V6/showthread.php?240608-New-to-Audio-Help-with-Understanding-RecorderAlso, if you're recording just the one mic, set your second record channel about -6dB lower than the first. This is your safety channel in case of sudden peaks. You only need one channel (track) of that audio in post, so use the primary track until there's clipping, then fall back on the safety.
I have a Sound Devices 702 recording device. Something I'd love to be able to do during interviews is use one lapel microphone, but record one channel high and one channel low. That way, if the subject has an abrupt volume change, I'd be able to use the lower gained channel.
Hmm, I would call Sound Devices, but I don't think you can route one input to two faders.
I think my biggest question though, is how loud is someone yelling, and why aren't you trimming your fader's and letting the limiter keep things in check from being clipped? In my opinion the limiter on the 702 is amazing. Let it do it's job, while you do yours right?
