BenB said:24p, when you want the 24p effect in a 60i project.
24pA, when you want native 24p in a 24p project.
smpproductions said:yeah you can cut 60i, 24p, and 30p in the same sequence. You probably won't want to, but you can. The only time you will NOT capture and sequence something as DV NTSC 29.97 is when you are working with 24PA. for that you will want to add the pulldown removal and also edit in a 23.98 sequence.
