Shutter Speed - 180.0d
I was playing with the shutter speed tonight.
I am shooting at 720p/24pn.
It defaults to 1/60, moving down it goes to 1/24, and moving down again it goes to 180.0d.
What is 180.0d?
Also, what is the effect of turning the shutter off?
Thanks,
Chris
p.s. I am desperate for Barry's book. I hope he has overnight delivery. :)
In a film camera, the shutter is a mechanical device that allows light to pass through for a determined period of time to expose the film plane to the right amount of light to create an image on the negative.
The shutter in most motion-picture cameras is called a rotary disk shutter, because it is actually a circular disk that has a segment cut out (most usually half of the circle - or 180 degrees of it, like a half-moon shape), causing the shutter to have a light and dark cycle (open and closed) as it rotates. Exposure is made when the cutout segment of the shutter passes in front of the film. The film is advanced during the dark cycle.
If you're shooting film at 24 frames per second (and the shutter is open 180 degrees), the shutter is "open" for half of that time (it's closed during the other half since it's constantly rotating), so the shutter "speed" (or the time at which the film is actually exposed) is 1/48th of a second. In the film world it's expressed in the degrees and in the video world it's expressed in the fraction of a second.
Since the HVX is a video camera, it doesn't have a rotating mechanical shutter like a film camera, but instead the "shutter speed" is indicative of how long the CCD is actively susceptible to light (and "exposing" the image) during each frame. In this case, the "shutter speed" works just like it does in a film camera.
When you press the SHUTTER button behind the LCD screen, it activates the shutter selection and you can press the + and - buttons next to the SHUTTER button to change the value of how long the shutter is open (or how long the camera is exposing the CCD during each frame). The faster the shutter speed (the smaller the fractions), it means the shutter is open for a smaller amount of time (think just a little sliver of the shutter would be cut out of the circle to expose the image), and therefore you get much sharper, crisper images because the motion is captured very quickly. Because the CCD is exposed for much less time with a fast shutter, you also need more light to expose your image correctly (you open up your iris to compensate). You've likely seen this kind of effect in movies like Saving Private Ryan and Gladiator during the intense action scenes. It's almost a "choppy" look. On the other hand, if you have a slower shutter speed (bigger fractions) it's the equivalent of a bigger slice of the circle being cut out - you can even go more than half of the circle if you want to) and that means the CCD is exposed for a longer duration of time. As a result, you'll get more blurred motion in your images and you will have to close down your iris because you're letting more light through.
In addition to the presets the camera provides for you by moving up and down with the + and - buttons, you can also specify an exact shutter speed of your choice. To do this, you go into the SCENE FILE menu, select the SYNCRO SCAN option, and choose the value you want. In the case of VIDEO CAM mode, the shutter speed is represented as the fractions; ie, 1/24 of a second, 1/48, 1/60, etc. In the case of FILM CAM mode, the shutter values are expressed as degrees of the circle; ie 180 degrees, 90, 45, etc. They are the same thing, you just have to make a conversion from one to the other depending on what mode you're in.
Basically, it's just fractions and math; since a normal film shutter rate on a motion picture camera is 180 degrees of the circle, and when you're shooting at 24 frames per second, you're exposing the film for 1/48 of a second. You pick either FILM CAM mode or VIDEO CAM mode depending on what suits you better (be aware that some functions of the camera are only available in VIDEO CAM mode and some are only available in FILM CAM mode. The manual has more information on this).
If you're scrolling through the different SHUTTER options and you see 180.0d, that means your SYNCRO SCAN setting is set to the default 180 degrees. Typically, that's probably what you're always going to want to leave it on to capture the motion and feel of film (unless you have a specific need to change it to alter the mood of your scene). Many music videos, for example, are shot at slightly faster shutter speeds to make crisper, more "modern" images.
I always thought that turning the shutter "OFF" defaulted to 180 degrees, but I've seen Barry make a post that instead of 1/48 at 24fps, it actually defaults to 1/50. I'm not sure why that is; maybe someone else can shed some light on that. But I would recommend shooting at 180.0d (or 1/48, in VIDEO CAM mode) to get the cinematic look you're used to seeing in the theaters.
Shutter speed is just one of those camera things that you have to really understand to be able to control, but fortunately it's been a part of every camera back to the dawn of photography so there is plenty of information about it out there. If I'm too confusing, look it up on Wikipedia. :-P
Hopefully that helps some.
Haakon,
Thanks for the incredibly detailed explanation. It is very helpful.
So, if I understand correctly, it sounds like when I am shooting 24fps I should have it set at 180.0d instead of 1/60 for more of a filmic look (unless I am going for some special kind of look).
Chris
Setting shutter in degrees keeps the setting consistent when changing frame rates - so that your motion rendering remains the same. However, you need to adjust for light
for example at 24 frames - shutter of 180d is 1/48 or half of each frame rate time period. at 48 frames - shutter of 180d is 1/96 BUT STILL half of each frame rate time frame so the motion rendering will be the same (same amount of motion blur) BUT because shutter is faster you will need more light - open up the iris one to two stops.
