Should I get a SyncMaster 2043NW for 75 bucks?
NSBFTW
Carbonite Member
Is a used Samsung SyncMaster 2043NW for 75 bucks a worthwhile deal? I will be editing HMC150 footage on it. This is the cheapest and best monitor I have came across in my local classifieds. Here are the specs:
Name Samsung SyncMaster 2043NW Black
Description Flat-panel (TFT), 20 inch, max resolution 1680x1050 pixels, built-in speakers: No, 5.1 kg
Monitor Type PC Monitor
Screen type Flat-panel (TFT)
Screen size 20.0 Inch
Widescreen Yes
Touch Screen No
Dot pitch mm
Maximum resolution 1680x1050 pixels pixels
Frequency at max. resolution Hz
Color depth 16.7 million
Pixel response time (rise+fall) 5 total, ms
Contrast 1000:1
Brightness 300 nit (cd/m2)
Horizontal viewing angle 170 degrees
Vertical viewing angle 160 degrees
DVI/VGA Input VGA
Number of Inputs Single
Video connections D-sub
Color Black
Built-in Speakers No
TCO 95/99/03/06 TCO '99
Power consumption 40 Watt
Miscellaneous
Dimensions (including stand, WxHxD) 46.9x39.3x21.7 cm cm
Weight 5.1 kg
Sure if it looks and works well, it should as long as it doesn't have a million hours on it. For 75 bucks your not really risking a lot and you if he's asking 75 that usually means you can talk him down to $50. Then again you can buy NEW 20" monitor for a low as $120.
He was asking 100. I tried talking him down to 50 but we met halfway at 75. He said its under 2 years old, should I still go for it?
