should I buy Rycote INV-7 or INV-6 for AT875R?
liukaitc
ok just bought first mic at875r as people recommend here
bought Rycote inv-7 shock mount..can still fit in, but seems at875r a bit short for it..
should inv-6 be a better one for at875r?
The INV-7 is adjustable - Just unscrew one of the Lyres and move it to the middle position (you need a 3mm hex driver if I remember correctly).
There are three possible spacings - wide, middle and narrow (depending on whether you move the front or rear Lyre).
If the INV-7 in standard format is only slightly too long, I would set it to the medium size.
