Motion is similar to PART of AE. AE does a lot more than Motion, though. Motion is very good for what it does. Shake has won Academy Awards. AE takes a large investment in time to learn to use it well. Shake also is going to require a large investment in time. Motion is fairly easy to learn and has a great interconnectivity with FCP. It really comes down to what you want to do and how much time you're willing to invest learning the program. There are some guys here that are really good with AE like Kai and Matt Grunau. I've seen some great work with Motion, too.hmfilmer said:what the diffrence? is Motion like after effect? which one is better?
SomewhereinLA said:Motion is useless.
Actually, unless they've recently changed it, you get QuickTime, not QuickTime Pro.BenB said:QuickTime Pro
You can no longer buy any of them seperately.
Blaine said:Actually, unless they've recently changed it, you get QuickTime, not QuickTime Pro.
I'm going to back track a bit. Yes, you get QT with the Mac. BUT you have to pay to have the upgrade to QTPro. IN FACT, whe FCP upgraded from 4 to 5, I had to but a NEW upgrade to QTPro. QTPro isn't a requirement for FCP, it just makes like a lot easier with many things that you'd like to do. Apple calls out QT 7.0.4 as requirement for Final Cut Studio.BenB said:QTPro has always come with the pro apps, you HAVE to have QTPro to run them. You get regular QT with your Mac right out of the box. The pro apps install QTPro. It's always been that way. You couldn't run FCP or Motion or anything without it.
CaptainMench said:Here's what I use Shake for:
Keys
Roto work
Compositing
Dust Busting
SmoothCam
Fixing BlownOut shots
Morphing
Time Mapping
Here's what I still use AE for:
Text effects
3d graphic work
Photo motion
Here's what I use Motion for:
Ummm...
CaptM
Nik Manning said:Here is what CaptM could use motion for.
Keys
Roto work
Compositing
Text effects
Photo motion
Not to mention Motion is Light Years faster than AE or Shake. If motion had motion tracking I would use it as a dedicated realtime color corrector. Add colorista
