SGpro Rev3 Sky 120Shutter
Bertholt4
Is it normal that I can see the spinning disc when filming sky with 12oer shutterspeed and sgpro, (I think the batteries are full)?
a lot of adapters' ground glasses become visible at higher shutterspeeds. though, how stopped down is our 35mm lens? that could contribute.
Bright sky's are the biggest challange for an adapter regarding grain.
What lens are you using, and what is the aperture setting?
To piggy-back off of Wayne I try to avoid putting my adapter in a situation where grain is visible. As wanderful as these adapters are there are limitations so if you see the gg at 1/120th...don't use that shutter. I know it may be contrary to your artistic choice, but to get a grainless shot you may have to compromise.
Hmm. I shot some 1/120 footage with the SGPro on my DVX and didn't have any problems at all, but granted my aperture was something like f/2 or 2.8. I was shooting some 60i footage for slow motion in post.
The grain masking issue is one that affects every adapter out there...spinning or not. I do most of our grain testing with snow as a background (not hard to go here) which is likely the toughest test. Stop a lens down enough in that situation (worse with wider angles) and grain even on a very fast spinning adapter will be very evident. The only way to avoid it is to make some serous bokeh compromises.
Thanks for clearing up, And Yes it was a Wide - 28mm Nikkor but aperture was not fully wide open. Have to test a little bit more.
Hehe, I forget how cold it must be there in Canada. Do you get a lot of Kinney's near you? My Grandfather, god rest his soul, was Canadian and moved to the UK during the 2nd world war, so I have Canadian blood! In fact he was a mounty for some time. My surname is very rare in the UK.
Bertholt4, would be nice to see some of your tests!
Jeeps, I think there's a shoe store with that name around the corner :-) WWII brought many war brides here from the UK, and you'd have to figure many Canuck grooms just stayed put too!
