SGPro 35mm adapter plus loads of extras
SGPro 35mm Depth of field adapter REV3 model with spinning ground glass.
Flip module so that the image is projected the correct way up. Without this, the image would be upside down and flipped horizontally which you get with cheaper adapters.
SG Follow focus.
15mm Support bars.
2 Base plates.
Shim kit so any camera can be used with this kit.
72mm ring size.
2 Batteries for powering the adapter.
1 Lens ring for follow focus
1 Hard case for transport
http://www.gumtree.com/london/96/75830496.html
