SGblade ordering now online!
Wayne Kinney
DVXUser Sponsor
Hi Guys,
As promised, the ordering system for the SGblade is now online. www.shoot35.com
If you are a previous SGpro owner you are entitled to a £50 discount from any SGblade package. Please email us at sales@shoot35.com for your promotional code!
Thanks, Wayne. I ordered mine yesterday.
One thing you might check, on the check out page the final total line doesn't add up the £'s correctly. It shows a higher total £ than the line items listed above it, and thus a higher converted USD amount. Fortunately that appears to be a display error as it did charge the correct amount (£ and $) to my paypal account. Not sure if anyone else noticed this or if this only shows up when it has to do a currency conversion.
One last thing, I ordered the RotoRazor2 and now I'm thinking I probably should have ordered both 1 and 2. Is it possible to get that added to my order?
Thanks again for keeping your promise of getting the order page up on the 18th. If only more companies would be as reliable. :)
I just received my r3 version 3 weeks ago... still happy with it, but now when I see this new version, I only want to cry.
Wayen, Glenn.... any ideas, who knows, it is a Xmas time, miracles can happen.
Great look though
Thanks guys,
Not seen that problem before, your order did come through at the correct price. I'll keep my eye on that.
You can certainly add ROTOrazor 1 to your order, please email Glenn at sales@shoot35.com.
Does this adaptor come with a 77mm thread for the EX1?
Has it been corrected like the Letus extreme so it has edge to edge sharpness with the EX1?
Steve
The Blade has a 72mm thread but you can order a 77-72mm ring with the blade.
Confirm this with Wayne, but im pretty sure the new achromat is made with the EX1 in mind. He is testing the EX1 and blade as we speak (probably)
Ordered mine day before yesterday; transaction went smoothly.
Looking forward to trying it out on my next project...
Congrats, Wayne and team!
Certainly the nicest looking package to date. Excited to see more upcoming footage.
Looks freaking sweet, Wayne!
I'm looking forward to getting my hands on one of those production units :thumbsup:
Im meeting up with Wayne tomorrow to do some demo filming with the blade and Hocus Focus.
Should be good :-D
Will post some footage shortly.
With Video Forum at Earls Court only a few weeks away, will there be an opportunity to have a play with one at the show?
wayne...i have a few questions, also since i havent seen any footage from the beta testers with the razor2.
1. Razor2: is this the same exact gg from the sgpro? meaning this Blade version performs the same exact way as the sgpro but with a different chassis?
2. Weight: what is the weight difference of the Blade and the SGpro, mounted on the new rails vs the old rails?
3. How many stops gained with the Razor1?
4. Clarification on the rod support system pieces...why isnt the tripod clamp included since that is a necessity with any rod system? Is there a screw that connects the blade onto the bracket so that there's no slippage?
5. Where are those beta testers' footages???
6. Anybody testing with the HMC150?
7. Is the lens mount the same exact design as those from the SGpro? Meaning the lens mounts can be exchanged between the pro and the blade? I'm thinking I can get a blade outfitted with an EOS mount since I already have an f-mount.
1. I believe it is the same Screen as the Rev3 model.
2. weight is identical to the letus extreme.
3. Rotorazor 1 came to about 1/5th to 1/4 stops less sensitive than the LEX. so i would image that would be .65 stops.
4... dunno
5. http://www.dvxuser.com/V6/showthread.php?t=154105
6. I tested on the XH A1
7. from what i recall, the lens mounts are the same. They are screwed into the front end which has the backfocus adjustment. So yes.
Hey Wayne, have you guys done testing with the dvx100a?
Yes, Anders Nettli (beta tester) has a DVX100. This cam is tried and tested with the SGpro so will have no problems with the Blade.
Steve
The FLIPmodule comes with a 72mm connector but you also get a free step ring with the Blade, so you can choose 77-72.
Yes, we went out today with the SGblade, new flip module and an EX1. We did some Steadicam shots with the Hocus Focus wireless follow focus (the HoFo works great, btw).
We are pleased to say that the bigger prism and wider gate has solved the vignetting issue. We will be posting the results in the SGblade testing zone this week!
We will not be there, unfortunately. We are however planning on attending the 'Focus On Imaging' event at NEC in February.
1: Yes, it is the same GG/diffuser element, however with the new coatings used in the Blade, you will see an improvement in contrast and light loss.
2: Once all the final parts come in, we will take official weight measurements.
3: With the Blade and FLIPmodule, ROTOrazor 1 results in approx 1/2 stop of lightloss, with ROTOrazor 2 its approx 1 stop.
4: You have 2 options.
The first (£149) and least expensive includes the 'tripod connector', this bolts to the main base plate of the rods support, and the tripod connects to this.
The second option (£179) includes a second 'rods clamp' and the tripod connector bolts to this clamp. This means that the tripod connector can slide up and down the rods, allowing the user to perfectly balance the rig on their tripod.
5: Beta Testers thread is here: http://www.dvxuser.com/V6/showthread.php?t=154105
Also, as mentioned we went out today and shot some footage with the EX1, this will be up this week.
6: We have no tests with this cam at this time.
7: The SGblade requires our new mounts with 'outer collimation rings'. These are backwards compatible with the SGpro. If your lens mount does not have a collimation ring, it cannot be used with the Blade, however.
Me n' Wane met up today for some SGblade and HoFo testing.
All went smoothly, shot with the EX1.
Im having a few issues getting the footage on my editing setup, but until then, heres some photos of the rig in action.
And finaly, the Shoot35/HoFo grip truck :-D
