Once you get the Rail and base plate adjusted to you camera (5-10min) it is as easy as loosening 3 allen screws, and pulling(25sec.) So all in all it is fast, brevis is the same deal, If your threads are not screwed the same every time you screw the Brevis on, you must loosen the allens on the Achro and line everything up again, wit the Sgrails, you are all ways aligned.
Jon
