I'm a relatively new user to Premiere Pro 1.5 and I've found some limitations that I haven't accepted until I hear it from pros.
Avid has the ability to apply effects to multiple transitions or clips at the same time. Does Premiere have that ability? If I want to apply the same color correction to 23 clips, I don't want to have to select it and drag it to each one and then adjust the correction. I would also love to be able to put the same effect on several transitions at once. It's a work-flow thing to save time, and I feel it's tedious to have to do the same operation over and over.
Is there a way to split stereo audio into two mono channels? If I have one person on a mic on the left channel and another on a mic on the right channel, I either have to cut the clip between comments or have very little control over difference in levels.
I'll probably have more, but that's good for now.
