David Evans
Hi guys,
When you're finishing sound mixing (I'm using Davinci Resolve to edit the full project), where do you place the loudest sound in the mix? I think Resolve is full scale, so it maxes at 0db. The most audible bit in my project should be the voice over which I'm placing at -5db at its loudest. Soundtrack is around -20 to -10. Everything else is falling where it should, accordingly. I've been using generic speakers to edit (I don't have monitors) and now I'm doing a pass using headphones. Everything sounds nice except if I do a stress test and push the volume way up. I mean, way louder then it's comfortable. In that case, the hisses in the voice over start to appear, but this is to be expected right? Or am I supposed to get everything lower in the mix? I was watching an episode of Hannibal in the same system, using the same headphones and no matter how far I push the volume in my PC, it never gets that loud. I mean, it was definitly mixed to be way more silent than my project.
Any trick I'm missing here?
Thanks!
Thanks!
