serious 35mm adapter back-focus (collimation) errors
Lenilenapi
Carbonite Member
I had a rude awakening this week that could be of interest to everyone who is using a 35mmm adapter. If other people's experience is better let me know, as maybe I've just had bad luck and am off base with this criticism.
On a hunch I took my 3 adapters in to a camera repair department that had a collimator. If you don't know what a collimator is, it's an optical instrument that sends a pattern of cross hatched lines into a lens system so that the pattern is perceived by the imaging system as if it is coming from infinity.
Before many of you were born I used to work in a rental house checking the back focus of lenses on 35mm and 16mm packages before they went out using the collimator. It is standard procedure in a cine rental house, and I know some of you with film backgrounds *are familiar with this.
It is very easy to tell whether a lens is backfocusing correctly with a collimator by checking whether it comes in to focus at or near the infinity mark and especially by whether a zoom lens tracks focus from telephoto to *wide angle correctly. By the way I'm talking about the back focus of the 35mm lens on the adapter GG screen, not the backfocus of the video camera's lens on to the *35mm adapter from the other side. That's a different problem and easy to adjust.
It's always been confusing to know whether my adapters were backfocused correctly because the rules for still lenses are unclear. Sometimes *a still lens is supposed to hit infinity at the end of the barrell movement and sometimes it *is supposed to go past it. Some still zoom lenses are supposed to track perfectly, but it isn't considered as important for stills as it is in cine and supposedly many still lenses aren't expected to track.
I already knew that virtually every adapter I have owned - Redrock, Brevis, SGPro and *Letus have all come to me with the backfocus misadjusted. That was obvious just trying to get infinity close on each one. (BTW my SG Pro was second hand so it may not have been Wayne's fault.) *The others all came from the shop that way and in some cases I have returned them and they still came back misadjusted.
However I thought by now I had *set my Brevis and my SGPro correctly and I had just received a new Letus from Hien that he assured me was checked carefully. (Actually from my own tests I was doubtful about the new Letus but it seemed close anyway.) The annoying thing was my lovely 80-200 f2.8 Nikkor didn't track on any of them and I didn't know whether the fault lay in the lens design or the adapters.
So last week I went into Adolph Gasser's in San Francisco where I checked 10 lenses on 3 adapters and compared them to 2 Nikon bodies. (The collimator was a beautiful old optical instrument built by hand by Adolph himself in 1950. Adolph had been my boss years ago and was one hell of an inventor and designer. His son John insisted on accompanying me because he has sentimental attachment to the instrument. John got into it and kept bringing me different lenses and bodies to cross check our results.)
Well it turns out all three adapters were still misadjusted! Not as badly I'm sure as when I got them, but they were still *all off. *I was able to correct the Brevis and the SGPro with screw adjustments that are pretty simple to do, and low and behold - with proper adjustment of the mounts *- My Nikon 80-200 and my Tokina 28- 70 both tracked perfectly. *I later tested the adapters in real world situations and the collimation was accurate , the lenses performed better and tracked.
What is the problem here? I have been concerned for a long time that many if not all if our friendly manufacturers do not use a collimator *in their shops. Perhaps they never worked in a rental house.
I don't know what happens in every shop, but at least in a few I surmise from conversations that they have trusted measuring the physical distance of the mount with a depth gauge and figured that was sufficient. They may have been checking inside the shop to see whether the lenses seemed to focus at the distance markings on the lenses they were using as another test. I don't know whether the problem is that tolerances are simply too fine to easily measure or perhaps that the cheap lens mounts vary in their own depth.
Whatever methods they were using, they have often been insufficient. When I received my new upgraded Nikon mount from Letus I was astonished to find that it was not the same depth as my previous mount and hit focus at a different distances. At this rate I'm afraid to trust the reliability of interchangeable lens mounts.
A collimator is cheap! Less than $2000. *A lot of 35mm camera assistants carry one in the field . These manufacturers should be checking every unit before it goes out with a lens they know. Its fast, simple and accurate! *I sent this to Cinevate, SGPro, Letus and Redrock before posting. *Dennis at Cinevate is already investigating getting one. Wayne at SGPro just emailed me as well asking where to find one. The only manufacturer I know of is "Richter " and you can find them at <http://www.chamblesscineequip.com/catalog/richter_kollimator.htm>.
Meanwhile to you guys in the field - *See if you can find someone with an optical bench who will check your backfocus. On the phone they may tell you it won't work with your rig because they've never seen anything like it, but i can assure you it works very well.
(BTW - I just spent about 1.5 hours fumbling with my Letus and I think its finally right ( based on my known zoom lens) and I'll double check on the collimator again next week. I wish there was a better method of fixing back-focusing on the Letus. I got my directions from another user and it was a very wanky method, but maybe I just am ill informed about this one.)
Lenny Levy
And never been an AC or DP on an actual film shoot. I too have always found it odd that backfocus (aka flange focal length/depth) hasn't seemed to be a big concern to either the manufacturers or the buyers. Coming from a film background, I'm astounded at the impreciseness of the 35mm adapters I've come in contact with.
But they all come from a DIY background making these things in their garages, so to speak. With that perspective, I guess it's not surprising. 35mm adapters are not nearly as precise as stuff you get from a 'real' company when they're being cranked out, to order, from parts sourced from who knows where.
Cinevate's new collimation feature is a step in the right direction, but in my experience it's only a baby step since, as you have experienced, the equipment isn't set up correctly when it's sent out the door. At least there is a way to adjust it even if it is complete trial and error.
That's the best news I've read in a long time. IMO it would be a huge step forward if adapters were actually calibrated accurately and didn't rely on trial and error by the user to set them up corrctly. :thumbsup:
It's too bad that so many adapters have that problem. Obviously it's not a problem for the still camera manufacturers, so it appears to be something that the adapter makers could overcome with better design/manufacturing processes.
Unfortunately, now if someone comes out with an adapter that has a precision mount that does not need backfocus adjustability...
...it will probably be viewed by the marketplace as somehow 'lacking'!
Hope they collectively fix this!
I'm scared. My new LE arrives Monday or Tuesday with Achromat upgrade, EX and HVX compatilbility, and the Nikon upgrade. I read that back focus can be adjusted with the new Nikon mount. Is this true? Or do you have to open the rig up and break out the jeweler screwdrivers and calipers?
I'm not shocked that none of the adaptor makers have a collimater in the garage. Hell, we just got over vignetting, flipped images and edge to edge softness this year. I'm sure in the coming months as they've improved just about everything, collimation adjustment will be the final frontier and they'll design their revisions / upgrades with easy back focus in mind.
Please don't attack me for hating on Gepetto. The adaptors are now running 1400 and change. Collimation is long overdue. As Leni said, checking it is standard practice in any rental house, it needs to be before an adaptor's sent out.
It doesn't matter whether it's an adaptor or Panavision, all lens mount systems will need their back focus tweaked sooner or later.
Tim, I don't see anything for adjusting backfocus on the New Nikon Mount. Maybe its hiding from me though.
The thing that gets me is that checking back focus with a collimator is so easy and fast, its amazing that no one has been doing that so far.
I didn't get any instructions from Letus about how to adjust backfocus. Usually Hien is very responsive but he must have gotten very busy. I got an email form another user (Shane) who told me how to do it (supposedly instructions he got from letus) but I wasn't happy with the method. I had to open the unit up ( so much for the clean room) and then slightly pulll out these pins by hand while using a calipers to make sure it was even. Actually I'm surprised I got it. Maybe there is a better method. Thanks to Shane in the meantime.
Lenny
Wayne,
Thanks for pointing that out, and thanks for adding that to your mounts.
How does the adjustment work though? Steve doesn't say anything about it, and I didn't get any info with my mount. Do you loosen the screws and then turn the ring or just push forward and back in a sleeve?
Lenny
Im not to sure about the Letus mount.
The SGpro's Nikon mount has a threaded ring. Sorry for the bad photo below, it was taken quickly with my digicam just to illustrate.
Loosening the 3 setscrews allows the back focus adjustment ring to be rotated. 1 full turn = 0.75mm of movement, so fine adjustment is easy.
hey wayne... i just got my spgro a couple of months ago and just ordered an m42 mount last week. will it have the corrected back focus on that mount. will i be able to correct my original nikon mount that came with my adapter?
I just got my SG with the EOS mount a week or so ago. Any options for us Canon users?
Looking at the mount I don't see anything adjustable. From early observations, my mount seems to be collimated properly when measuring from the tab on the top of the adapter (ground glass position). Is there a rough release date estimated for the newer mounts?
Wayne,
I've been fine correcting my backfocus using the four screw on the back on the unit as you directed me last year. Is there a reason to prefer using the Nikon mount?
I guess it is advantageous for each mount to have its own correction if you want to switch between mounts - say PL to Nikon.
Lenny
Just like any small company starting out, most start in the wonderful garage/basement. However when trying to fulfill the low cost market of the adapters as people expect, It is hard to stay within budget and maintain a "fair price".
An adapter sold at $900.00 - $1200.00, really would cost the company $500.00 - $800.00 ( also depending on bulk deals, material used, etc.. ), and lets not forget about if something in the unit was to malfunction, the money it cost to replace that + shipping both ways (believe me it adds up). So at a profit margin of not even 75%, it's very hard to fit things like that in. You want precision, you'll have pay for it.
Bringing in items like a collimator, contour projectors, MELOS, etc.. these measuring devices start to add up $$$$ and most little companies can't afford them at first or even know how to use them. Not to mention the extra time it will take to make sure every item/unit is set perfect with them. That would mean another person added to the payroll and the extra time in testing (slower eta). Yes this should be a standard in the adapter business, but no one has come forth to set it yet. If it does, I'm sure the price will go up on units.
You have to remember this is something that started in someone's basement and has slowly worked its way to being mass produced. Basically, use your caliper to set the flange, and test the lens with measuring tape is the way it's been done.
Have you tested the P+S adapter yet ? I'm sure this unit has been through just about every test, but then again this is why the P+S cost more (precision).
my 2 cents
I'm with Twocik and I'mnot even a manufacturer. One day someone will kick out an Adapter that's somewhere between P+S and the currents, running maybe around 5k? And it'll have all of this stuff built in, be the shizzle and still get complaints I guess.
I do expect the price of units to go up once all the user requests are implemented.
I disagree folks. I'm very understanding and sympathetic to the problems of these manufactures, but i suspect the problem has been lack of knowledge not funds. A collimator is pretty cheap as far as I can see, and I suspect it would take far less time than current methods. Its really a no brainer unless I'm missing something.
Anyone who's worked in a rental house with a collimator would have been as stunned as I was to discover they weren't being used. I hope this gets corrected.
Who knows though maybe I'm totally off base - I'm not an optical engineer.
Lenny
"I disagree folks. I'm very understanding and sympathetic to the problems of these manufactures, but i suspect the problem has been lack of knowledge not funds. A collimator is pretty cheap as far as I can see, and I suspect it would take far less time than current methods. Its really a no brainer unless I'm missing something."
I've actually looked into one a few years back, but used my money on cnc machines instead. Leny I agree that the knowledge part does have something to do with it, but money is still a huge part of it. I know $1000.00 - $2000.00 doesn't seem much at first, but this is only one of many tools you'd need. Just to go over a few things needed to assemble a precise adapter, you would need ( leny I'm not calling you out, just thought I'd share with everyone) :)
- CNC Mill & Lathe
- Licensed Cad/Cam & Control software ($$$$$)
- Materials ($$$)
- Tool bits & collets ($$$)
- Turning tools & fixtures
- Measuring tools
caliper
depth caliper
height measurement fixture
dial indicator
and the list goes on.
- Tap & Die tools & tap guides
- Electronics & Tools
- Screens/GG ($$$$)
This is just a few to go over, so yes in my opinion and experience, money plays a huge part. As for the companies that are making them which are doing a fantastic job, it's just a little problem that needs to be corrected which I believe will be very soon.
To answer your question about time, yes it would take a little more time to set each FD. The way some adapters are being manufactured is by using measured distance rods, which are then set/glued into a measured blind hole (leaving the front mount or back casing adjustable). Giving you greater or less distance away from the GG when needed. The flange distance is then corrected by the depth on the mount/fixture.
The Brevis micro-collimation system has been available on all of our mounts (both SLR and cinema formats) for almost a year now...so folks could easily adjust. We've taken the time to shoot a tutorial video and posted it online to guide our users through the subject at the Cinevate Video University. An overview of equipment that we and our partners use to produce a single Brevis adapter would easily run into the millions. A collimator is insignificant in this light...but is it the answer to the issue? We've purchased one, but I don't expect perfection...here's why:
Because we expect up to 7 different mounts to be used on the adapter, and our imaging elements interchanged often, dealing with collimation in a precise and simple manner was predicated a long time ago for the Brevis35. It would be much simpler to just offer one hard mounted configuration, but even then, lenses require collimation adjustments internally to get them perfect. What we've done basically is removed the need to ever do this, by placing an adjustment on the adapter that takes into account all the various hardware we expect folks to use. You don't need a caliper to measure anything in our system, just a tape measure and your lens markings. Setting backfocus on a camera with a B4 mount is actually even worse. Although you can and should measure against your B4 lens markings, the manufactures just have you change the adjustment until zooming in and out doesn't change your focus! Dramatic temperature changes and lens mounts/remounts can minutely change this adjustment and our HPX500 lens manual advises you to check this regularly. An adapter is really not that different.
Keep in mind that collimation can vary between identical mounts, (say Nikon), so even a correctly adjusted adapter on one lens may not be perfect with every other lens using a Nikon mount. For perfection, you'd need to get each lens in your collection collimated too. Thats why the rear element/set of most lenses is adjustable.
From what I can see in this thread, "similar" systems to ours are being emulated elsewhere as folks realize how critical collimation is to lens performance.
my 2 cents
Gear to check whether it's working right before leaving the shop should be par for the course. One collimator is all you need to quickly and accurately check the back focus. Even when I was in film school the equipment room had a collimator mounted on a work table and using it was routine (as lenses were always going out - especially zooms). This is not the piece of gear that sends your prices over the edge. In fact, it may do the opposite.
Collimator = 2 grand (roughly the sale of 1 1/2 adaptors (spread out over x number of adaptors over the life of the collimator).
Checking collimation = perhaps 2-3 minutes / adaptor (some will be less some more because of adjustment). Or say 20 / hour. At 20.00/hour for labor it would add 1 dollar / adaptor. At 10 an hour 2 dollars. Five an hour would be 4 dollars.
Cost of not having a collimator = returns, repackaging, adjustment, shipping, dealing with countless correspondence, and loss of goodwill (read: sales). Can't put a number on this yet. But my guess, a collimator and a little QC shouldn't cost more per unit and would probably save money in the long run.
The PS comparison I find somewhat dated as they were an exclusive when it came out , China wasn't a factor and were catering to a much lower volume / high per unit price market. I wouldn't be surprised that their markup is astronomical as they're such a low volume item.
How do you figure 500-800 for costs of an adaptor? Curious.
I would like to see the low cost adaptor makers actually produce a "pro" model that has better build, adjustment and precision at cost that still makes it "low cost" relative to PS. Say 3-4 grand. At that price they could add much of the precision pros want but still at a price that doesn't have you weighing in on a RED.
