Z zoomin Member Apr 19, 2006 #1 Hi Im having troubles understanding all the different NTSC sequence setting in FCP. There are four- NTSC 4:3 NTSC DV 3:2 CCIR 601 NTSC (40:27) CCIR 601 NTSC .sq 4:3 What do they each mean. Im working in standard DV footage.
Geoff_R Veteran Apr 21, 2006 #2 If you're working in Standard DV Footage, you only need to understand and work with NTSC 4:3 for now. That's the one you should be working with for DV Footage. Now if you're asking out of curiosity, I'm not too sure what the CCIR sequences are for.
