Should my compression setting be at interlaced or progressive if we shot with the dvx at 24p and the capture preset. We are adding some graphic from after effects too.
Not a DVX guy, but pretty sure at the 24p and not 24pa setting you'd be using interlaced if you ingested the footage as is and that's what your working with. If you've processed the footage to be 23.98, then your timeline would be progressive. Again, not a DVX guy, but that's what I'd imagine you'd want.
