Sennheiser Wireless replacement
dantewaters
The CL100 that came with my G2 system looked like the one at Markertek or Sennheiser website, but the ones that came with my G3's are a heavier cable with a molded 3.5mm end.
I was thinking about this the other day, as I have no spares for this cable. BH has this listing which seems to indicate it will work. I didn't understand the hot pin comment. Could someone explain this further please. A couple of the reviews say this is a better cable than the Senn OEM version.
http://www.bhphotovideo.com/bnh/controller/home?O=WishList.jsp&A=details&Q=&sku=287325&is=REG
BH has several other cables in this category, but most don't have the screw on 1/8" male plug which is a problem waiting to happen.
Grant
Grant
This cable is specifically to connect the Sennheiser receiver output to a Studio One XLR adapter. It says it's wired with pin 3 hot which is the reverse of normal XLR wiring where pin 2 is signal hot and pin 3 cold. This means the phase is reversed compared to a normal mic. The Remote Audo CASENEK100 adapter is wired for conventional XLR inputs. www.remote audio.com If B&H doesn't have it, Remote Audio is a division of Trew Audio and they can get it for you.
I could be mistaken here but the CL-100 cable for 100 G3 receiver is also used as the second antenna for diversity - I wonder if aftermarket cables take that into account. I haven't pulled my CL-100 apart - but perhaps it's just a standard 1/8" TRS to XLR cable - then any would do provided the 1/8" TRS jack was threaded.
And just for the record, the "flimsy" CL100 that came with the G2 was fine, while one of the 4 "solid" CL100's that came with the new G3's was bad out of the box. :)
Not trying to diss Sennheiser, bad cables happen to everyone. :D
