I have a Sennheiser MKH 70 shotgun mic. I went to disconnect the cable the other day and pin #1 pulled out of the internal Male XLR connector. There are 4 screws at the end of the mic, which I removed expecting the end to pull out. It doesnt. There is a plastic sleeve in there and i have no clue how to remove this in order to fix the Male connector.
Does anyone have any experience fixing these mics? The XLR should not be rocket science to remove. But, it is beyond me how this comes apart. It is a rather expensive mic and I dont want to kill it trying to figure it out.
I have to leave out for a 7 day shoot half way across the country thursday, Im in a real bind to fix this.
David Walker
P.S. I tried to add a little solder to the end of the pin, then place it back in the socket it pulled out of, heated it with the hopes the solder would fuse itself back to the mounting inside. It was a no-go. I dont want to heat the heck out of the pin and burn up something inside.
David Walker
