gelojtaboada
I recently made a great deal and bought a used ME66/K6 from BH Photo, mint condition, no signs of use, just like new...
My main problem here is... Im getting a very low audio signal from this mic... Im quite concerned because I've heard this is one of the hottest mics out there, with a 50mV/P, right? And im getting a very low low sensitivity from this mic... Either with my Nikon D800 and my Zoom H6.
I'm mostly going to use this mic with my Nikon D800E, and got myself a Kopul LMT100 - Low to High Impedance Matching Transformer (1.5') to use with it. Yes, I know plugging a mic into a DSLR is terrible, but sometimes thats your only option...
The problem is that im getting very low levels from this mic, making me push the preamp gain almost to its max... And of course, I'm getting completely unusable audio from this setup... which is quite... disappointing. And I get it, DSLR preamps are BAD... but i was expecting a better result considering the high sensitivity of the ME66.
Im also doing double system with my Zoom H6, which for documentary can be uncomfortable and slow at times... And here it comes my beggest concern:
When I use this mic with my Zoom H6 I'm still getting very low levels from it... Which makes me push the Zoom's preamp gain high, resulting in high noise and hiss audio.
My settings pluging the ME 66 to the Zoom H6 are:
Yes, its low signal, Im boosting the earphones out to 100% and im hearing it low, even when I listen to it on my computer.
Going any higher in the gain knob will result in nasty noise showing up..
I would really appreciate your thoughts, your recommendations, and your help to solve this problem.
I hope everything is clear, and understandable.
Thank you Thank you in advance!
Im quite disappointed... Specially with the Zoom H6 ME66 combo... Noise floor is terrible, i have to push the gain to 50% on the zoom to get a still quiet signal, even when recording in a very controlled enviroment (Mic placed 9in away from my mouth, rigged in a boom pole, ponted down). If i push the gain knob on the Zoom just a touch higher, nasty noise start to show up, and my levels aren't enough...
Pretty useless for field shooting, Im making a documentary, and its CRITICAL to get good quality audio without huge and advanced systems... the smaller, compact, and comforable, the better..... Im swithcing between tripod, glidecam, lens swaps, and moving at all times... all fits in a single backpack and a belt... No assistants, It's just me out there. Hope someone understands..
Im wondering if this is normal with this combo... if someone has the experience with using this combination. I want to avoid investing $350 on a JuicedLink preamp... I'm going to take a while to afford it!!
Filmmakers out there who are using the Zoom H6 and the ME66/K6, is this normal?? Any advice on this combo??
Thanks for your support and help!
- ME 66 plugged via XLR to one mono input in the Zoom H6.
- 48V Phantom powered.
- I made a custom XLR with a Rapco calbe and Switchcraft connectors.
- Channel gain is 50%, which is the #5 in the gain knob.
- No -20dB padding on the Zoom H6
- Microphone placed 9in above my mouth pointed down
- Closed room, quiet..
