Do you mean select everything from the curser to the end of the project? (Right click and choose select events to end) Or do you mean just all of the clips that the curser is touching. For that use the edit selection tool (the arrow with the dotted box around it), and select everything at the curser, then you can split them all, move them all (hit G to group) or whatever. Or you could click the top track you want to select, and then shift click the bottom one, or you could ctrl click each one you want to select.
You can also use scripts that do this, as a single button process. If you only have 2-3 video events under the cursor, drawing the selection as suggested above is best. If you've got more than that, a free script or two can be found out there that select everything directly under cursor.
