hopkins802
Hey All,
Seeking opinions based on experience for a good / fairly lightweight run n' gun tripod for wedding filmmaking this year. My main camera setup is a Sony A7sII in a Smallrig cage on 15mm rails with the Sigma 24-105mm lens and a 5.7" monitor. All rigged up it's about as heavy / big as an FS5 setup would be.
I just had the chance to try this tripod out from a friend:
https://www.bhphotovideo.com/c/prod...otto_mvk502055xpro3_502hd_pro_video_head.html
Here are the things I liked and things I need to address before spending money on my own new setup.
Pros:
Super smooth fluid head, I liked the size of the head as it really felt like it would hold my setup fine, even with my heaviest lens which is the Rokinon 135mm f/2.
Lightweight and easy to carry around. I found it very easy to lock down the head, and just carry it around by the lens. They're not carbon fiber, but I'm not ready to spend that much on legs yet, so that's okay.
Quick to deploy legs and adjust height.
Cons:
Obviously there is no quick leveling head, which I will need.
The legs were pretty good..but could have been more robust for sure
I'm not stuck on any brand, I'm open to checking out Miller, Oben, Benro and Manfrotto. I do like the single column legs because they make it so much easier to carry around. I'm definitely open to mixing and matching brands to create my own custom setup if people have favorite video heads matched with favorite legs.
Thanks a lot!
-Dan
Pros:
Cons:
Thanks a lot!
-Dan
