maximgorky
Hello. I'm a newbie on this board. And not very tech-savvy - so please forgive me any glaring stupidity!
I am a producer trying to coordinate some work to be done by two different editors. One who is going to digitize my video content. The other who will do the editing. Both are working on Macs with Final Cut. Both are on OS 10.5. Not sure exact versions of FCP. But both pretty recent I believe.
I have been advised that it would save digital space if instead of digitizing my content (currently SD on digi-beta) at "10 bit uncompressed" - we instead should digitize using "Pro-Res HQ".
I was informed that it would be virtually the same visual quality as "10 bit uncompressed" - but would use up much less space.
The issue is that the first editor - who will be digitizing - does not seem to be able to find the "Pro-Res HQ" setting in his FCP. And he has a recent version of FCP.
I had passed on the following info to him (that my second editor advised was all that was needed):
Go to "Easy set-up"
On the drop-down menu select:
"Apple Pro-Res" or it may say "Apple Pro-Res HQ"
After trying to do this - my first editor wrote back to me as follows:
There must be some variation in Final Cut systems even from the
same time period, because in the Easy Set Up zone I can't find this setting.
The only ones that mention Apple also mention HDV.
When I tried the setting listed as:
HDV-Apple ProRes 422 1080p2p - and then tried to bring in video in that setting, it said "Unable to initialize HDV deck", as it was looking for an HDV player hooked up thru a Firewire cable. So I don't know what the answer is here.
Is this that my digitizing editor is looking in the wrong place for the "Pro-Res HQ" setting?
Could it be that he has a version of FCP that doesn't yet have it? (Though I was told that "Pro-Res HQ" has been around for the last 2-3 years - and the FCP being used is certainly that recent)
Or are we missing something more obvious?
All suggestions most welcome!
many thanks
Go to "Easy set-up"
many thanks
