Hi all,
I have been attempting to record the best signal to noise ratio possible with this microphone setup. I still have a lot to learn so forgive my ignorance. I can get 'great' audio when using the mic input and output, but I wasn't able to get a reading when using line inputs and outputs. I understand it is better to use line? This is how i set everything up:
1.hvx set to -50db and mic alc turned off, input 1 and 2 set to line level, phantom power turned off
2.switched everything to line level, 48v phantom power,turn on sd302 and put on 1khz tone
3.adjust hvx input levels so that the square white dots hit the first white line(-20db)
am i missing something??
