ScopBox and On Location questions
I downloaded the trial version of ScopeBox and I can't seem to figure out how to remove the redundant frames while recording from my HVX200. I tried with both 720p 24p and 1080i 24pa. Is this because it's the trial version? or am I doing something wrong? I was able to remove the 1080i 24pa pulldown in Final Cut Pro easy enough, but couldn't remove the redundant frames from the 720p 24p captured quicktimes with the Frame Rate Converter for some reason.
Also does On Location remove redundant frames? Does On Location write quicktimes to Mac formatted hard drives? if so, do I need MacDrive installed on the PC to do it?
OnLocation:
Yes. Yes. Yes, though you can capture to any drive as Quicktime, then make your transfer to a Mac-formatted drive later.
