1) Is it possible to save / render a key done on a piece of footage, once you are happy with it, retaining the transparency, so no more rendering is needed. What is the best way to do this? And will this benefit workflow?
2) Also, I’ve just discovered that you can work with proxies (lower res versions of hi res files, in After Effects) Is this possible in Final Cut? and is this the same as an EDL (Edit [FONT="]Decision List)?[/FONT]
Regards for any help
[FONT="]Jon[/FONT]
[FONT="]Jon[/FONT]
