Samsung Monitor Suggestions??
Hi,
After reading tons of reviews, it seems that Samsungs are pretty hard to beat. If you use a Samsung monitor for video editing what would you suggest and what to stay away from? I want to setup a two monitor system one for editing with the other for viewing. I need both monitors to be capable (switchable) of viewing 4:3 and 16:9 aspect ratios correctly.
I am currently looking at the following monitor, but I've heard that TN monitors are a no no. Is this true? Other than that I like the specs; 2ms, digital/analog interface, etc.. Please give me your professional opinion. Camcorders that I use are the Sony DCR-VX2100 and the Sony HDR-HC7 Thanks, Ray
P.S. I know about the "S" and "A" series issues on this particular monitor. S is preferable.
Samsung 226BW
Panel Type: a-si TFT/TN
Viewable Size: 22.0" Wide
Pixel Pitch: 0.282mm
Brightness (typical): 300 cd/m2
Contrast Ratio (typical): 3000:1 DC
Response Time (typical): 2 ms (G to G)
Viewing Angles (H/V): 160/160
Native Resolution: 1680 x 1050
Aspect Ratio: 16:10
Maximum Color: 16.7M
Interface: Analog/Digital
Input Video Signal: Analog RGB, TMDS Digital Link, DVI
Sync Type: Separate H/V, Composite, SOG
Input connetcors: 15-pin D-sub, DVI-D
Plug and Play: DDC 2B
Power Consumption: 55 Watt (max.), <2 watt (DMPS mode
Stand Type: Simple
Cabinet Color: Piano black
VESA Wall Mount: 100 mm
Magic Technologies: MagicTune with asset management, MagicSpeed, Magic Contrast, MagicBright 3
Special Features: DVI (HDCP), Swivel and tilt
Dimensions (W x H x D): 20.3" x 16.6" x 8.6"
Why would you need it to be "switchable"? If these are to be computer monitors, there's no need of for that; the software you're using will display thing properly. Besides, I don't think any widescreen compter monitors do that.
I would caution against the idea of using one for "viewing," if by that you mean you're going to have the preview of your work on one monitor while you edit on the other. If you color-correct or add effects or what have you, what you see on your computer screen may well not be what you see on a TV screen once you're ready to watch it. Things that look fantastic on the monitor may look horrible on a TV.
Hi,
Thanks for the reply! I agree with you when it come to viewing. As for the switchable question I'm just concerned about not stretching out my 4:3 aspect ratio do to being a widescreen. I am just now learning about LCD monitors.
I just got back looking at this monitor at Circuit City in which I definately like the looks of it. While there I looked at the Samsung Series 4 450 LCD TV in a 22" This might be a good choice for the viewing monitor since it would give me a truer color for TV play back during editing. The videos I make are made in MPEG2 (DVD) for TV play back. I'm thinking that this combination might be the perfect pair. Thanks, Ray
Hi Everyone,
Well, here is my latest find; A Samsung 2253BW 22" monitor which I'm told replaces the 226BW. What I like about this monitor is the ability of using it as DVI or Analog RGB. Correct me if I'm wrong, if I was to have two of these one setup as a main monitor with the other setup as analog would'nt the analog monitor be close to what you would see on a TV? If so, I could use the analog setup for color correction during editing. One of the things I like about this monitor is that it is switchable for differant aspect ratios. Another scenario which may be much better is to use this monitor as a monitor and use a LCD TV such as the Samsung Series 4 450 for viewing/editing purposes. This LCD TV is also 22". The link for this LCD TV is also found below.
I know I probably sound a little ignorant on this, but I want to know which would give me the best setup for video editing. This is why I'm turning to you folks that are experienced for your help. I appreciate all of your input and help.Thanks, Ray
