I have uploaded footage shot on the HVX and HPX and edited in FCP and compressed in Quicktime (settings below) to a player at www.jazzguitarheaven.com . The video that begins playing at the opening of the homepage has played well in all servers except Safari in which the stream stutters when changed to full screen. I wanted to know if anyone could suggest different compression settings (Keyframe rates, bitrates , etc.) that have worked with them in uploading stream problem free HD. Also note that the safari which experienced the problem was running on a PC, could this be the problem? Any help is greatly appreciated.
-Mike
Quicktime Export Settings
Under the Video Tab
File Format MP4
Video Format: H.264
Data Rate: 900
Optimized for Streaming (checked)
Image Size: 1280 x 720 HD
Check preserve aspect ratio using letterbox
Frame rate 30
Key Frame every 30 frames
Under the Video options button
Restrict profiles to: Main
Encoding Mode: Best Quality
Under the Audio Tab
Audio format: AAC-LC (music)
Data Rate: 128 KBS
Channels: Stereo
Output Sample Rate: 48kHz
Encoding Quality: Best
Under the Streaming Tab
Enable Streaming (checked)
Maximum packet size: 1450 bytes
Maximum packet duration: 100 ms
Optimize for sever (unchecked)
-Mike
Under the Video Tab
File Format MP4
Video Format: H.264
Data Rate: 900
Frame rate 30
Under the Audio Tab
Data Rate: 128 KBS
Channels: Stereo
